Another fiddly thing to fix if the slats have gone out of sync or something is stuck in the vents, like a coin. Mine looked like this, the vertical slats were broken so I couldn't control the airflow to the driver:
How to remove the air vent
Pull the bottom of the vent away to start to pop the clips, use a pry bar or gap opener and work from bottom to top.
How to remove the air vent trim
Pull the whole vent out of the dash. Then lever up the 4 clips to remove the front trim. Push the trim off as you lever up the clip - it can be done with fingers. One of my clips was already broken, so I guess I wasn't the first person to try this fix!
How to disassemble the air vent slats
Starting with the horizontal slats, pop them out of the frame from the lefthand edge (this is the driver's side, RHD model).
Lay them out in order for later, be careful to retain the metal coupler!
The vertical slats pop out at the top from the back of the frame, although you can push them out from the front. Again, retain all the parts in order. I found one of my slats was in the mouth of the pipe that supplies the air, so I could retrieve it. If you've lost a slat, I think you will struggle to rebuild it, as the couplers are designed for the slats to hold it all together.
