I've just built up my Evo Design kitchen pod and because it backs onto the back of the driver's seat (not the side of the van) the angled steel gas pipe runs back into the side of the unit. There isn't room for a compression fitting. I can see a few options:
1. Try to bend the steel pipe to straighten it and give space for a compression fitting. There's not much room for this and it will mean a 180 degree bend on the 8mm copper gas pipe.
2. Bend the steel pipe 90 deg so it reverses direction (180 deg bend) and gives room for the compression fitting.
3.It looks like I can loosen the connections and reverse the steel pipe so it leads the opposite way, which will be to the side of the van. The screws that would need to be loosened are covered in red 'no tamper' paint and there is some red paste of some sort where the steel pipe joins the feeds to the hobs (highlighted in red, with new pipe position in blue). Is breaking these seals a stupid plan? What is the connection from the steel pipe to the hobs? EDIT - would still no give room for connections.
4. Drill through the side of the unit and run the copper from there around the back
Messy.
I'm thinking pipe benders and option 2.
3.
