Fuses SC16 and SC47
Anzelmas
Hi, m8s!
I have Transporter T6 2017.03 in my garage. It has current leakage problem, 0.16A when sleeping.
I found that leakage stops when I remove two fuses: SC16 and SC47. If I leave one of these fuses, the leakage don't stop. It remains the same - 0.16A
My question: what do these fuses control?
Elsa doesn't give much information. Both fuses are connected direct to Central Electronics module.
When I remove SC47 - all lamps not working and the car starts and dies. When I remove SC16 - haven't noticed big difference.
I really need your help.
Assuming I have the correct fuse diagrams for your van....
Not surprising the engine didn't run with 47 removed - Surprised it would even start
16 looks like the windscreeen wipers
I found another fuse list with the correct fuse sizes and both SC16 and SC47 just say "onboard control module"
How are you testing the leakage? The van will have some things powered up for a while even after everything is turned off, and even then there will be things like the security system still active.
I am testing with millivoltmeter. When I remove these fuses I get 0,04A which is normal for this car when it sleeps.
Owners manual has no fuse assignment. It's the same for all newer cars.
Elsa also say "onboard control module". Because of that I am asking here.
Did you see this thread?...
What if you do a VCDS scan and checked for faults ( as a baseline)
Then remove the two fuses and rescan to see what additional faults appear?
That might give you a clue to what is causing the issue.
T6 2017.03
SC16 and SC47
Fuse SC16 is 5A, fuse SC47 - 25A
1.6.4 Fuse assignment for fuse holder C -SC- from June 2016:
16 - Fuse 16 on fuse holder C -SC16- 5 A - Onboard supply control unit -J519- (T73b/39)​
♦ Internal supply​
47 - Fuse 47 on fuse holder C -SC47- 25 A - Onboard supply control unit -J519- (T73b/13)​
♦ Turn signal​
♦ Brake light​
Well, probably doesn't add any information but I'm curious to see if your results would be different...
After removing SC16 fuse I got fault code 00532 - Supply Voltage B+ Open Circuit. After removing SC47 fuse I got fault code 03430 - Terminal 30 for Turn Signals and Brake Lights Open Circuit. I did actuation tests for turn signals with VCDS - both sides OK. But test for brake lights - not OK. All brake lights work without problems, lamps installed as they must be.
I decided to replace Central Electrics module. I think something wrong is inside it.
I presume you have done a reset of the control module ?
I left the car with negative contact disconnected for several nights because I don't want to charge battery in the morning. The same shit...
