Fuse Box Cover/trim ?! .
CALLAKN
Electrician / Linesman
T6 Legend
Am I doing something wrong ?! Trying to pull this off and it won’t come... I’m taking the lower dash apart pretty much !!
Also, gear knob?? For removing all the white part of the dash... what do I need to do ?!
Thanks in advance
pull it hard, or use a trim tool. - for small fuse box lid only
For removing all the white part of the dash... what do I need to do ?! - removing the 3x lower dash plastics
take off side airbag panel,
remove glovebox,
unclip DSG top assembly,
remove lower footwell plastics
remove light switch
undo all screws
remove the 3x lower dash plastics
Removing the Gear lever gaiter
Removing the DSG selector
So remove the light switch bottom right of steering wheel yes ?
once you have done it for the first time its easy.
just be careful with the DSG top piece, the circuit board and wire connection is very fragile
yeah noticed it was very fragile, hopefully I didn’t damage anything when unplugging.. not taken it off the knob tho... left it on in the end
the PRINDL bit will push through the hole at the top.
you can remove that center bit easily - just unplug the 12v socket
like this . . .
20180511_141348-jpg.22165
That looks a little scary and I’m an electrician
to be fair, it’s not in my way at the moment so it can stay... going to put some silent coat down... not sure how much difference it will make considering the thickness of the matt that’s already down there from factory.
