Furthest distance gone when range says 0 miles
Ran my old T5.1 to about 5-10 miles beyond 0 on the display but only because I was close to home and was planing on removing the fuel tank to install a set of Caravelle rails and didn't fancy attempting it with a half-full tank of diesel!
It’s an entertaining question - I’m sure we’ve all crawled into a petrol station “on vapour” before.
I did read somewhere that it’s better to not let the T6 drop below a quarter tank to maintain the efficiency of the regens and DPF. (Equally, I could have imagined that!)
I used to do this on a Seat Leon FR company car back in 2008, I never ran out and regularly went 20/30 miles past 0! Never did find the cut out point :D but the range was clearly conservative!
  • Haha
Ran my T5 out twice, once with five miles range showing, once with 15 miles range ...
Some of these gauges and fuel computers are a lottery.
I try and fill the van as soon as I can after the light comes on - on the range that can be anywhere from 35 to 75 miles left depending on how gently it's been driven. A couple of times I've either not got close to my preferred filling station, so I've done 5-10 miles on the range being 0.
I had a Ford Escort TD with a fuel gauge without a warning light. That ran out outside my front door one day and the vacuum caused bent some solenoid or other.
My Altea ran out once with 15 miles range and my Clio once ran out on the way to a fuel station showing 30 miles of range.
When I was trade plate driving, I was frequently driving cars with zero range on them as the auction sites would normally hoover all of the fuel out of them and put a gallon back in. Except sometimes when they didn't bother putting any back in...
Didn't Clarkson go 50 miles past Zero in a petrol Jag?
A Top Gear episode I seem to recall, heading to Blackpool?
Bit of a bugger when the engine dies coasting down a windy hill and you loose power assisted steering and brakes
The flip side to this is we are on tour and bought minimal diesel in France, just enough to get into Spain. We arrived in Pamplona and the needle was just outside the red on the gauge. The light hadn’t come on, and the MFD was saying 80miles range. I filled up and it took 77.5 litres, I have the 80litre tank. I’m assuming that there’s a fair margin of error in the stated volumes and ranges.
I once coasted my T4 into the petrol station as it ran out on the way in. That van was blessed.
Until it wasn't.
I did the same once when i was young and strupid..it was a pool van for a company i once worked for, the person who used it prior got it back to the yard almost empty and i discover this at 5am as I'm about to set off for a trip miles away where turning up late wasn't an option. Now the location of the yard was rural and local garages were not open at that time so, with little options I headed to the motorway junction and set off to the nearest services which were a couple of miles away. Initially went well, i was tailgating lorries and trying to use as little throttle as i could, however when we hit the mile marker for the services it started coughing and cut out soon after...i managed to roll it off in to the services and to the pump, so got away with it.
You would have assumed the person who left the van nearly empty would have got a bollocking, but given it was my immediate superior that didn't happen.
  • Haha
