Fuel Gauge
Jimmy007
Hi all I wonder if anyone can help, my T6 had a flat battery today and wouldn’t turn over, I put it on a trickle charge fo a bit and got it started but now my fuel gauge is not showing any increments the fuel light is on and it’s reading 0 miles in tank ? Has anyone ever experienced this before ? Thanks
Try disconnecting the battery for a minute
Yep. Has that sorted it?
No still nothing reading :(
Try a bcm reset. Disconnect your leisure battery if you have one. Disconnect the starter +ve and touch the lead on the -ve side. This will discharge any capacitors in the bcm
Ok I’m not confident in that as I’ve no clue in what I’m doing, I do also have a leisure battery
I put £10 of fuel in and it done the trick weirdly, there was nearly half tank in it anyway
Thanks for the help though
