Fitting Bumper Drl Help
Blitz
ok im wiring up my DRL lamps. The instructions say cut into the near side headlight loom. However their is bugger all room and very little wiring to play with. The offside has loads of room making it easier. The wiring colours are different though so if I use the same wire positions i.e. 1 and 10 in the connector block will these be the correct wires? Or is that too simple ??
Grant
