That’s a very good point that you made.. thanks for reminding me not to have my number plate obscured... much appreciated your advice.and get nicked for obscuring your number plate £1000 fine
TheAre you expecting a plague of locusts to follow the coronavirus?![]()
The way the year is going anything could happen yet... but hopefully not a plague of locusts.Are you expecting a plague of locusts to follow the coronavirus?![]()
I‘ve studied Fluid Mechanics and my gut feeling is that the bare clean net will reduce airflow more than the insects.
It might have a use in Australia or Africa I guess but at least the van won’t get Covid 19.
That's different . . . . . . .
Thanks but no thanks. I'd rather wash off the few insects that stick to the front than have a mesh screen with rotting insects collecting on it.
It is actually made for the Australian outback so it will probably see off a kangaroo..Will it stop bird strikes......![]()
Hmm .. not sure there are just a "few insects" ? Maybe dawdling around the UK but it's a whole different ball game after 9hrs straight at 80mph through France to The Alps. You cant even see your headlights or front end. 100% insect coverage, layer upon layer of the b*ggers![]()
What’s next bush tucker trials....but fair play if it works for you then thats goodIt is actually made for the Australian outback so it will probably see off a kangaroo..
For camping its very practical. Rock up at the site, scrape the contents of the screen into your Ridge Monkey... lots of protein there and its freeWhat’s next bush tucker trials....
I have to admit that when I read some of the replies to my post I was gob smacked how negative some of the replies are and also felt belittled by one or two of them.. it really did take some restraining but what do you gain by lowering your standards to the same level...@Wayne.wirral - those are the most restrained and polite responses I think I've ever seen following such a barrage of negative comments, well done to you sir!
I was originally wondering if someone had invented something that wasn't actually required but I do get it. Ref the number plate comment, there's loads of people on this forum with illegally spaced/altered number plates and the police appear to be letting that 'slide' so you probably have nothing to worry about - you can sort it there and then to their satisfaction too. I also don't think you need to worry about restriction of flow to the radiator either - these things have been tested in Australia where their winters are warmer than our summers.
