FitCamX Dashcam (power from rain sensor)
Have I got the wrong version?
I would suggest you have as both the ones I've installed have fitted like a glove, no trimming required at all!
Fire it back to FitCamX - their after sales support is pretty good!
Thanks. I did wonder and FitCamX replied that I should trim it, which I have done:
One more question on the camera. I get a blue square at the top left when viewing the feed through the app. Is this expected?
It turns out the blue square is showing because the rear camera is not connected, which is a bit crap but makes sense.
I don't have the rear camera fitted and mine doesn't do this.....
Same on both cars I have fitted these to.
Mat
Hmm, ok thanks. And you’re using the latest versions of the FitCamX app? I am on iOS.
Fitted mine now with the correct housing to the rain sensor using there splitter loom. However I now have a message “automatic headlamp fault” Indeed the auto headlamp function has stopped working. I have unplugged the camera and the auto headlamp works again. I’m thinking a hard wire would be a better plan. Has anyone used their hardwire kit? Where is the closest switched live?
did you find out the reason for the automatic headlamp fault error? i have the same error
I never found why I had the error. So ran to a switched live to the fuse box to the right of the steering wheel I fitted a 1 amp inline fuse. All good
