Fault code P2457
GLC1980
Hi all, I’ve just had the engine management light come up and it is Fault code P2457 egr cooling system - performance problem, has anyone had any issues with this and is it an easy fix or anything I can do to clean egr system out etc, can has been driving fine and don’t do any short runs at low revs or anything, it’s 2018 150 with 64k on the clock.
Thanks for any help
Flashing glow light or emission light (=engine symbol)?
Possibly "pump for exhaust gas recirculation cooler (V400)" is not performing well enough?
Does your diagnostic tool read also VW specific codes to detect component failures, or only generic OBD codes (emission)? Just to make sure there isn't altready a code related to the pump?
Can you read coolant temperatures in and out of the cooler?
Expected behaviour explained in below
Hi, no it’s just a cheap code reader that just throws up a code, there’s been no other codes came up just the one about the cooling so assumed it wasn’t directly related to the egr itself, I’ve put a cleaner through it juts in case and then reset it so will keep an eye on it to see if it comes up again
Reactions: mmi
