I have a newly installed 200w solar system to dual charge my batteries through a Renogy DC-DC charger and MPPT controller. I still have my old 100w portable panel and thought if I ever needed the extra PV power I could just plug it directly onto the leisure battery like I used to do. However I have a couple of cracks in my confidence and need a bit of expert reassurance…or otherwise before I add it. It has a PWM controller and plugs directly on to the leisure battery with crocodile clips. Hopefully there is no conflict between the PWM and MPPT controllers as although connected to the same battery they are independent of each other. The output from the panel on the pop top is 23.9v so within the Renogy controllers maximum of 25volts but I’m hoping that if I plug the portable panel directly into the leisure battery while the one on the roof is still connected nothing will get fried. In other words, can I have both systems on at the same time?
