I have a 5G router (ZTE MU5001) that is unlocked & I've added a couple of little TS9 connected aerials to it:-
My questions are, do I need to consider an external mounted Antenna to escape the Faraday cage effect of a big metal box on rubber wheels? Is the Faraday cage effect as catastrophic as one is lead to believe? If an external hardwired antenna is going to change my life, then which one do I need to look at buying and installing?!
I have discovered that there are adapters to go from the varying aerial connectors supplied on antennas to the TS9 outputs/inputs on my router.
Appreciate your guidance!
