Bit of a a weird one T6 150 T32 67 plate
ThunderboltFMF
VCDS User
Early this morning at about 00:40, the van alarm went off.
I got up to investigate.
Side door unlocked but not open.
Tailgate unlocked but not open.
Alarm resets on the remote but neither lock.
Front doors lock on the remote.
I think, battery ( it’s 00:50 now and I may not have had 100% clear thoughts) and add try and manually lock the van.
Then add a slave/jump battery to get some power in.
After a few goes it locks.
I go back to bed.
Thinking now, what happened???
Battery is OK, but nothing brilliant.
Random electrical issue?
Some sort of theft attempt?
Last year the van was opened but not started.
I will check it today when it stops raining cats and dogs. (Not raining last night)
Keys are kept in a faraday cage, with the wife’s car keys.
Puzzled.
Need sleep.
  • Sad
How many keys have you got?...
Where's the other one?
You don't need to put your keys in a faraday cage unless you have keyless entry and/or ignition - neither of which came as standard on the T6? The standard key fob only emits a signal when you depress any of the buttons.
How about VCDS & alarm log :thumbsup:
Will try and do.
Another job.
Not feeling the love for this van.
Has the battery been load tested? Just because it shows 12.?V doesn’t mean it’s good.
No, I haven’t had the chance, on a work break at the moment.
It must be goosed.
Annoyed as it is only about 3 years old. I think.
Well, perhaps "two birds, one stone"...
Please post blockmap files of both 09-Central electrics and 61-Battery managaement
1) Ignition OFF
2) Ignition ON/engine off
How-to create a blockmap file:
Note: only VCDS HEX-V2 or HEX-NET cables have the capability
[VCDS]
[Applications]
[Controller Channel Map]
- Single Controller Address =XX (use 09 for the BCM, and 61 for Battery management)
- Login or security access code: Leave blank
- Function: Measuring values
- Output: CSV file
[Go]
The result files (.csv) are saved into directory C:\Ross-Tech\VCDS\Logs
Thanks, I know this. All our keys live in a faraday cage as we bought one when Mrs got her last car and we want to keep things tidy. It’s just housekeeping.
1) Ignition OFF
[VCDS]
[Applications]
- Output: CSV file
[Go]
Will do, as soon as I can.
Work getting in the way.
Reactions: mmi
