Engine Oil Temperature Fluctuation
Jacobwilliamshort
I have a 2021 VW T6.1.
My oil engine temperature will intermittently start fluctuating and not settle on a temperature. This resulted in the engine management light (the coil warning light) coming on, on one occasion, and the start stop and ACC being disabled.
However, leaving the vehicle overnight seems to rectify the issue. I may not have any symptoms for a couple days.
The vehicle drives fine even with symptoms.
I took it to the garage and the only code showing up is a torque management system code: P00AF00.
Any thoughts on the cause of the issue? A faulty sensor maybe? Or a software issue?
How are you measuring the oil temperature?
If you are getting the engine management light coming on, there should be a fault code stored which may help with a diagnosis
How much and how quickly does it fluctuate? Mine changes all the time. As i pull uphill and wind on some power I can see it climb from 98 to 108 fairly sharpish then drop back to 100 as it levels out. It doesn't stay constant like the water temp gauge.
P00AF 00 = Actuator Module for Turbocharger 1- Stuck
I am reading the oil temperature off the digital gauge on the Instrument Cluster.
I think the only one stored was the torque management system code, unless the mechanic failed to mention another.
I'll have to get hold of a fault reader and check myself.
Many thanks, those are very similar symptoms. Would you recommend the same solution (diesel additive cleaner)? Or investigate the Actuator as you specified first?
The engine code is the following: DNAB
I am by no means experience in this, apologies.
Reactions: mmi
It's fluctuates rapidly, regardless of driving conditions (5-20c in a couple seconds). It normally sits comfortably on a temperature if conditions are uniform, and will change slowly due to changes in driving conditions.
Well, such an interpretation a kind of suggests the garage doesn't have proper tools for VAG fault finding and thus quite possibly can't read manufacturer specific fault codes - e.g. oil level/temperature sensor codes. Below just an example of T6.
Possibly a wiring, or the sensor itself, issue - thus intermittently cutting offmor shorting the connection. The dash display is heavily damped down so can't conclude much of it.
Does the engine have bottom cover or is all the wiring easily accessible to e.g rodents?
do you think a sensor failure could cause the other symptom
Not likely.
Fuel additive won't help. The turbo actuator needs attention. Also a proper diagnostic tool would be more helpful.
From my experience that rapid oiltemp fluctuation points towards a faulty sender - physical oil temp can not vary within a few secs. As said above run decent diagnostics
When you state 'faulty sender" can you clarify if that is faulty oil pump? Or faulty sensor?
Mant thanks for your patience.
It will be a process of elimination. One thing at time. First call oil temp sensor. As I said oil temp does not fluctuate wildly. The sure way is to get to root cause is get it plugged in to the Diags
