bebef1987
Hi everyone,
I’m looking for some help and real-world experience from members who have dealt with CXEB 2.0 BiTDI engines, especially regarding engine rebuilds and oil consumption issues.
Vehicle details:
Engine: CXEB 2.0 BiTDI
Year: 2016
Mileage: 181,000 km
Oil consumption: ~1L / 1,000 km
Aside from the oil consumption, the engine runs well: good power, no major drivability issues, and no permanent fault codes. DPF regenerations appear normal and I’m monitoring related values regularly.
I’ve gone through many existing forum threads, but I haven’t found a case that clearly matches my situation or a universally agreed root cause — so I’m hoping to get input from people who’ve actually dealt with this hands-on.
What I’ve observed so far:
I don’t see signs of turbo-related oil issues (no excessive oil in charge pipes/intercooler, no blue smoke under boost, no abnormal turbo noise)
No visible external oil leaks
Oil consumption is steady, not sudden or rapidly worsening
After inspection and discussion, my mechanic is suggesting a piston and piston rings replacement, suspecting internal wear as the main cause.
Additionally, from time to time I get a P042000 fault code, which seems to indicate that the exhaust / aftertreatment system is struggling, likely as a consequence of the high oil consumption. The error isn’t permanent, but it does reappear occasionally.
Before committing to a rebuild, I’d really appreciate advice from those with direct experience:
Is pistons + rings replacement the correct approach in most CXEB oil consumption cases?
Has this actually resolved the issue long-term for anyone here?
Are there updated or revised piston / ring part numbers or newer design variations that should be used instead of the original ones?
Any critical machining steps, tolerances, or known pitfalls?
Anything else worth addressing while the engine is open?
I’m not looking for guesses — solid real-world experience, measurements, and rebuild outcomes would be extremely helpful.
Thanks in advance, and I appreciate any insight you can share.
Vehicle details:
Year: 2016
Mileage: 181,000 km
