Hi
Just thought I needed to let every one know
That I have a 204 67 plate transporter which has had to go in for three erg flushs up to October 20 ?.
Then I started getting high oil consumption and smoke under acceleration ,nearly out of warranty I decided to get one year extended through vw?
Come January it was using 1 ltr of oil every 350 to 400 miles so i booked it in to vw for a oil consumption test?
IT FAILD? Four weeks later it has had a new Engine, dpf, cat etc but no ERG.
Two weeks after getting my van back and running it in, the engine management light came on? Fault ERG again ,now I'm told that instead of another flush it needs a new ERG as the coolant side is letting coolant into the valve turning into gel and causing a flow issue ? Luckily it's getting done on a good will?
From what I understand this is the common problem that caused the 180 bi turbos engines to fail?
Maybe I've just been unlucky?
If anyone else keeps getting told just to have there ERG flushed please question this?
All the best krob
All the best krob
