Electrics Dos & Don'ts
Andrew
Hi all -
I've finally saved up some brass and have bought an Evo Motion set of units..
I already have some slapdash units which I'll skip but also have full electrics including inverter.. Please note - I am an utter novice around the electrics so am a little cautious around what to stick my finger in..
Are there any Dos & Don'ts that I should be mindful of before tackling it.. My thought was if I disconnected the leisure battery then nothing it going blow me up.. however I do have a battery select switch on the panel so thought it wise to ask the experts..
Thank you...:)
Andrew
If you are new to 12 volt electrics, its worth tracking down a 12 volt wiring guide book for reference.
The correct use and sizing of circuit/fuse breakers
The mathematical calculations to size up wire size mm2 (not mm wire diameter) and resistance levels
The correct way to solder joints
Using a multimeter
Doing it right the first time, saves a lot of time later on trying to trace a faulty wire or connection.
