Hi, to help people, I thought I'd share this question I've been asked incase anyone else had been incorrectly told the same thing.
The Solow / Eibach 45mm spring we do is 100% made by Eibach. The reason it's not available on the Eibach website is it's exclusive to, and designed by us with Eibach. Eibach refer to it as a 'white label' product. We took the information from the springs Eibach made for VW for the 30mm Sportline spring. We then trialed different drops. The goal was to get the biggest drop without sacrificing ride quality. This is the best drop on springs alone you can get before the ride becomes 'crashy' We tried lower but after lots of testing, 45mm came up the best. It was surprising to us how even an extra 5mm to 50mm reduced the comfort.
If budget only allows for springs, we believe these are the best spring only option on the market. Ideally when lowering the springs, you really want to shorten the damper too. Thats where the Solow, Bilstein and Twin Adjust Projekt coilovers come in for the ultimate in comfort, ride, handling, reduced body roll and sway.
Anyway, I hope this helps others.
