I had 30 mm Eibach fittet to my T6 T28 (1550/1550). It dropped 40 mm on the front axle and 5 mm on the rear. Dissappointed... Can it be that they have given me 1720 springs at the rear?
My eibach 50mm are the same looks high on the rear sometimesMy T32 looked high at the back too but then I have no weight in the rear most of the time. I think it has dropped over time now though. They may just need to bed in.
Yes m8 standard shocks very surprised how nice a ride it isAre you running with standard shocks Andy?
I'm considering going with the Uberbus 50mm Eibach kit - which has an adjustable rear spring so they can get the van level.
Not cheap, but a lot less than coilovers.
Uberbus_Link
I'm still waiting on my eibach 30mm springs been told by my tps man there on VW back order and don't know when they will be getting them in
I’m no expert and could be completely wrong but I think 30mm is what vw drop the sport line van and I was also told that the springs they use are Ebach ones to. When I dropped my van I got advise to use B14 adjustable coilovers instead of springs. I didn’t want to spend that much so I ignored it and fitted the springs. I wish I did listen as am now trying to get the money together to do exactly that so paying out twice.Hello everyone
I,m not looking to cut the grass with my T6 t32 Kombi (Slidepod fitted) so i thought about fitting the Ebach 30mm springs witl it make the ride harder ???
I decided yesterday after posting my reply to this thread to book my van in for B14s and H&R ARBs. It’s been on my mind for a long time but the cost has always put me off but I am sick of thinking about it and think it’s time for doing. So it’s booked in for January as this is the first slot vanstyle have and I’m looking forward to it.The guy that carpeted my kombi said that he had seen this many times with Eibach 30mm springs being fitted to lightly loaded vans.
He suggested using Cobra springs as they drop evenly front and rear.
I did fit Cobra springs, and I can confirm that the drop on the rear is the same as the front.
I know folk like to use Eibach due to warranty concearns, but that didn't bother me.
Is the ride compatible for a every day drive.My experience Eibach springs were they high on the back and are made of cast iron ! If you carry weight or are converted to a camper if am sure they are fine. However i ended up paying out twice, once for the springs then for B14's and ARB's not touched it since. Money well spent and we live and learn.
Yes absolutely i used it for a few months wound all the way down. Then raised it 5mm front and rear. Swapped the 17" wheels for 18" and would say it drives a well as my wife's Golf gtd on 19'sIs the ride compatible for a every day drive.
I’m still on vw 17 at the minute the reason I asked is I was unsure about the ARB making it to stiff so Just gathering opinionsYes absolutely i used it for a few months wound all the way down. Then raised it 5mm front and rear. Swapped the 17" wheels for 18" and would say it drives a well as my wife's Golf gtd on 19's
I would say not. It just stops thats feeling of driving over your front wheels on roundabouts etc. A far more planted drive.I’m still on vw 17 at the minute the reason I asked is I was unsure about the ARB making it to stiff so Just gathering opinions
