That's interesting! However, I do notice you have done some 400 miles since last scan and obviously a couple of DPF regens.
It seems that you have cleared fault codes quite recently - which explains why the scan doesn't identify which fault triggered flashing glow plug light.
Quite obviously the culprit is the Mass Air Flow sensor as it's critical for engine to run properly.
In the blockmap engine off the MAF reads 1.03 g/s when it should be plain 0.
Engine idling the sensor reads 7.00 g/s when it definitely should read minimum of 8.2 g/s (for hot engine, slightly higher for cold).
So possibly just a dirty sensor?
To verify MAF sensor validity you could run the test below and post the logs - as the setup records a couple of additional parameters including air mass sensor
So it seems - inevitable P0401.
Well, visited a VW garage to be tested - the van had accumulated 30 events in ECU's memory since July 2021 (since 20 months now). Eventually managed turn on the emission light at event number 31 - thus had a priviledge to have EGR flow tested. The result - pending - the ODIS went to an unending loop without a concluding result.
Meanwhile, I think I have reproduced the EGR flow test using VCDS. However, I don't have any reference value to estimate the degree of EGR cooler blockage. Neither did ODIS tell the reference value (should have told but the computer...
EDIT:
Of course need to rule out any air leaks in engine air intake.
