Eberspacher not firing up
DAAS
Eberspacher problem. Went to fire my heater up today and nothing? I believe it’s a D2 or 4. It had error appear the other day but today has come up with this code. I can’t find original documents. If anyone could please help it would be greatly appreciated.
Ideally you want to check all the stored error codes. The last 5 are usually stored.
the only 51 code that I can find is:
I’ve had a few errors over the years, which when reset by pulling the fuse do not reoccur..
Thank you, I will try firstly to find where the fuse is as bought the van ready built. Can’t be rocket science?
No communication is usually a dodgy plug connection, not pushed in enough or corroded contacts.
At least it isn't a 51 code!
Going to have a look at the weekend and if not will get someone who knows what they are doing. Thanks
Hi, done what you said and worked a treat. Turned it on a couple of times today and fired up both times. So thanks for the advice.
