Drivers side window jammed then stopped working FUSE?
Your a VIP member your entitled to download the fuse box layouts a charts from the "download" section of the forum. It will also give you other fuses which are good to reference from and saves needing to ask again.
thanks i didnt know that
however, when i went back to it the window was working again so no fuse out
but it still jams so its off to the dealer tuesday
Have you upgraded front speakers and routed new wire incorrectly inside the doors so they are inside the window guide channels rather than outside them? I nearly did that on one door !!! :speechless:
Mine packed in as did Caravelle T6 on here. It didnt jam, but seemed like something was loose and it was heading that way. It was the regulator, which if i understood the tech correctly incorporates at least part of the framework that the window runs in. It necessitated some riveting.. to transfer the speaker brackets on to the the new bit. About a two hour job.
