Has anyone else had a similar issue and has anyone found the problem. T6 everytime it regens the coil light flashes even though it completes the regen, code is P0087 fuel rail/system pressure is too low.
Garage inspected it and fuel pressure isnt low and its running perfectly, no leaks on the fuel rail or anywhere. All 4 injectors were replaced a month ago so its not them plus had a new fuel filter a month ago. So we replaced the fuel rail sensor but still this issue persists. Fuel pump is fine has no swarf and is not suspected to be failing. Dpf is clean and unclogged. Van is perfect apart from everytime it does a regen. Anyone else have this issue? No loss of power or anything!
