Help with Error code P0087.
Lewisgeorge
Hi everyone,
I have searched the the forum threads but nothing comes up that fits my current situation and was wondering if anyone here may have any insights.
I recently bought a t6.1 startline 110 with some dpf issues. Fixed them with a new sensor and a couple regeneration cycles.
All was good for a couple hundred miles and then my first issue started. in 3rd - 4th gear, under acceleration. The response would cut for a split second and then kick back in. Then, when climbing a mountain road it went in to limp mode and started flashing the glow plug warning. I pulled over and stupidly restarted the van before reading the codes and they disappeared. fast forward a couple hundred more miles and a couple of little acceleration stutters here and there. I was driving home tonight and The van had a couple of bad acceleration cuts but they lasted 1-2 seconds each, and then the flashing glow plug showed itself. Pulled over and scanned to read the codes -
P0087 fuel rail/system pressure - too low bank 1.
Restarted the van and all is good again. I’m going to order a new fuel filter first to see if that helps and then maybe look at the fuel pump if that doesn’t work.
Has anyone had similar experiences and maybe have some incite to what It could be?
Thanks in advance.
Just to add if anyone does have any information. Van started on the button today but a couple minutes in to the drive and it started stuttering and the glow plug light was flashing again. Restarted the van and it’s gone for now.
