Dometic Recall
There's already a thread about this here;
Hope you get sorted
Has anyone or know of anyone who has experienced leaking from underside of hob unit it's such a risk of major catastrophe we all want and expect to be safe.
Dometic recall ….. Dometic. ( click on link)
This recall is for…Be safe check web site for update
SKUMODELFAMILY
9600027605Dometic PI8022 EUcooktop
9600027606Dometic PI8022 12V ignition AMcooktop
9600027608Dometic PI8023 AMcooktop
9600027609Dometic MO7123combination
9600027610Dometic MO7103combination
9600027611Dometic MO7123combination
9600027612Dometic MO7103 w/o holecombination
9600027613Dometic MO9722R w/o ignitioncombination
9600037308Dometic CE99-ZF EU heatshieldcooktop
9600037309Dometic CE99-ZF AMcooktop
9600037310Dometic CE99-ZF OEMcooktop
9600037313Dometic CE99-DF AMcooktop
9600037314Dometic CE99-DF OEMcooktop
9600037315Dometic KSK2007Rcooktop
9600037316Dometic KSK2007R 12V ignitioncooktop
9600037317Dometic PI9003cooktop
9600037318Dometic PI9023cooktop
9600037319Dometic MO9722R Piezocombination
9600037320Dometic MO9722L Piezocombination
9600037321Dometic MO9722R AMcombination
9600037322Dometic MO9722L AMcombination
9600037323Dometic MO9722R OEMcombination
9600037324Dometic MO9222Rcombination
9600037325Dometic MO9222Lcombination
9600037326Dometic MO9222Rcombination
9600049989Dometic MO9222L w. AC530combination
HOW TO QUICKLY CHECK IF YOUR COOKER IS AFFECTED
1. Is the installed cooker the original cooker you bought together with your vehicle?
If yes, please check the first registration or production date of your vehicle.
If this date is before October 2020, the cooker is not affected, and nothing needs to be done.
If the date is October 2020 or thereafter, you need to check the data label of the cooker.
If it is not the original installed cooker, you also need to check the data label of the cooker.
2. Did you buy the cooker from a retailer before October 2020?
If yes, the cooker is not affected, and nothing needs to be done.
If you bought the cooker from a retailer in October 2020 or thereafter, you need to
If you don’t have the exact date of purchase, you also need to check the data label of the cooker.
3. The data label should be provided together with the cooker manual.
If not available, the data label can be found on the bottom of the cooker.
If you have no access to the bottom of the cooker, your dealer/installer can help you with this check.
4. On the data label, you can find the SKU. If it starts with 96000… and is shown in the above list, your cooker is affected.
Example of a data label attached to the bottom of a cooker with SKU:
PHOTOS OF THE AFFECTED COOKERS ARE GIVEN BELOW BY WAY OF EXAMPLE:
The background to this decision is information concerning a potential leakage of the assemblies installed in cookers (cooker regulators and/or supply tubes).
DUE TO THE LEAKAGE, AN UNDETERMINED AMOUNT OF GAS CAN LEAK DURING THE SERVICE LIFE OF THE PRODUCTS WHICH CAN IGNITE WHERE A SUITABLE IGNITION SOURCE IS PRESENT. AS A RESULT OF THIS, A FLAME FORMATION CAN OCCUR AROUND THE REGULATORS. FURTHERMORE, IT CANNOT BE EXCLUDED IN THE WORST CASE THAT THE GAS-AIR MIXTURE EXPLODES. THIS CAN SERIOUSLY INJURE THE USERS OF OUR PRODUCTS BUT ALSO UNINVOLVED THIRD PARTIES.
SHOULD YOU HAVE PURCHASED ONE OF THE ABOVE-MENTIONED PRODUCTS, PLEASE STOP USING THE PRODUCT IMMEDIATELY, CLOSE THE SHUT-OFF VALVE AND KEEP IT CLOSED!
