They’re flat top 5mm LEDs with bezelWhich LED’s did you use? I assume they are indivual ones in holders rather than strips?
I may get some and do some experiments...
Got bored today so while I’m waiting for my genuine ‘velle doorcards I had a go myself. They look pretty good. They’ll be up for sale shortly
@YellowHound sorry mate I missed your first request. They are connected to the instrument lighting circuit that runs to the window switches. Blue/grey is +ve and brown is -ve. Currently, I think they are a little too bright, I’ve ordered some 1k resistors to dim them down a little
eBay https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/252024737412Thank you!
Where did you order your resistors from?
Use 1 per LED.@Deaky having a crack at these tomorrow. One question though.
Did you have 1 resister per circuit ie. Leaving the feed and then branching out to the LEDs or 1 resister per LED?
I've had an idea for puddle lights but more research required
The leds I got already have a resistor attached so you can hook them straight to 12v. I added one 1k resistor to the feed@Deaky having a crack at these tomorrow. One question though.
@mopardave they come on with the side lights. Yes, I added a white led to the door pull handle. The pic further up the thread was taken before I added the extra resistor to dim them down a little. I’ve since fitted caravelle door cards so the ones above will be for sale shortly.for god's sake....will you lot pack it in! I want all this interior ambient lighting but don't want to turn my van into a smouldering blob on my drive! But if anyone's thinking of doing a (total) idiots guide.....that'd be great! @Deaky.....have you also illuminated the interior door handle pull....and do they come on with the headlights or just on opening the doors (and then time out)? Either way.....bl**dy marvellous....respec' to all of you!
