Dipped headlight drivers side one bulb out
Chris82
Hi all,
I’ve tried replacing the bulb but it still doesn’t work, the rest of the bulbs work on the drivers side work so assuming it’s not a fuse,
Has anyone else had this issue. Any advise on where the issue could be would be appreciated.
Many thanks
Just to double check have you replaced it with a known working bulb, such as swapping left and right over?
I've had a faulty new bulb before that caused quite a bit of confusion.
So I didn’t bother doing that as I’ve tried both new bulbs out of the pack, but will be sure to give it ago before I go any further, just incase.
Hi all,
Many thanks
It could be the fuse. Headlights are fused separately for each side, and separate from the other lamps.
