Hi all, I have a Durite VSR on a T5.1. It's not start/stop.
The starter battery recently failed, despite Halfords testing and saying it was okay.
The leisure battery is an AGM xtreme.
I have a mains battery charger that is kept separate to the system for our cars and is AGM compatible.
People say to just connect the charger to one battery or the other and it'll be fine. However, if I connect to either battery then the relay opens and you have two uneven batteries?
I've noticed that the leisure battery needs a top up so how should I charge it to avoid damage to either battery but also make sure I get a full charge into the AGM leisure battery?
The leisure battery is under the driver's seat and so I need to remove the seat to get access.
