ctek D250se and sergeant 155
Degskiwi
hi all don't no if this is the right i am going to fit a ctek D250se into my van which has a sergeant 155 and c50 control panal what i would like help with is solar side of things should i use the ctek or should i bye a stand alone unit thanks for any help at all
Depends on the size of the panel you want, CTEK can only handle 23v VOC So if the panel you choose has a higher VOC then you’ll need a separate MPPT controller
Yeah sorry only told you half a story sorry about that but thanks for your reply I was thinking about having a panel fitted to the pop up roof later on but for now I will not need more than 100w what I meant to say would the ctek any good for handling solar or should I put something different
