you kinda could join them together . (as you said) ( in a temporary configuration)
provided they are same Ah and chemistry etc . . .
but what will happen is when you plug the second one in . . . .
if its a lower voltage than battery #one, battery #one will drain itself into battery #two as they will try to equalise them selves.
so you could end up with two half flat batteries . . . from one full & one empty
plus it will take twice as long to charge !!
cable distance and quality of the link between the two will play a part.
as will the Anderson connector, that will start to get warm above 40A.
what your suggesting is roughly the same as connecting jump leads to connect your battery box to the Aux battery...
yes possible, but proceed with caution.
and remember the ctek is 20A charge max (5hrs to recharge a 100A battery) (10hrs to charge 2x100a batteries)
To join your battery box to the existing, get this type of thing. - fit this to the van aux battery. then connect ur battery box in when you need it.
just remember the points above, and keep an eye out for any heat build up in the cable or connector if the battery is low. - just unplug a lets cool off.
one the batteries have equalised voltage it will be fine.
Specifically designed for varley red top type batteries, but can be used on a range of applications. Torberry Connectors has been the main UK Anderson Power Products© distributor for nearly 50 years.
rover.ebay.com
add at 50A MIDI fuse to it.
2 x 50 Amp High Quality MTA MIDI Fuse AND 2 x Fuse Holder. We operate a dispatch policy to ensure your parcel will be processed within 24 hours.
rover.ebay.com
with some of these . .
Sub-Type:Crimp Connectors. Material:Tin Plated Copper. Made of high quality pure copper material, good conductivity.
rover.ebay.com
and some of this . . . . .
Total: 127pcs. Heat Shrink. Type : PE heat shrink tube. Silicone Cable. Supplied format ( round or flat ): product is supplied flat. Add to Favorites. Full shrinkage Temp : + 110 C° maximum. We never close.
rover.ebay.com
