Hi,
Had van out on Sunday for drive, got back and after 30 mins decided to check oil, water etc. All ok, About an hour later put key in ignition to close windows and the coolant warning light pinged & started flashing? Switched off everything for a few mins, ignition on warning still on. Left it overnight hooked up Carista no codes related to cooling that I could recognise. Set Carista to live data and monitored (most patient other half watching the screen) and set off for home. Warning light came on again, temp stayed in 88 to 91 degree range. Stopped to fuel up and check levels, all ok! Set off , no warning light, turned off ignition on ferry, 30 min sail, switched on - warning light! Temp still in normal range, no loss of fluid. Is this a dodgy sensor or possibly something more sinister?
