Clutch pedal noise.
oiu82
Hi all,
I'm hoping someone can help identify an annoying clutch noise on my VW T6.
The gearbox and clutch are working perfectly with no issues changing gears, no slipping, and the clutch bite point feels normal. However, when I press the clutch pedal, there is a noticeable noise (see attached video).
The noise only occurs during clutch pedal operation and is becoming quite irritating. The vehicle drives normally otherwise.
Has anyone experienced something similar on a T6? If so, what was the cause and how was it resolved?
Thank you
Have you put your head under the dash while you depress it with your hand, sounds like something is out of place and snagging.
I did have a look under the dash, but the plastic trim is blocking most of the view, so I couldn't really see what's going on. I tried to find a video showing how to remove the trim around the pedal area, but no luck so far.
Knowing my luck, if I start pulling panels off without knowing exactly where the clips are, I'll probably end up breaking something 🤣
There’s a video on youtube, shows it in steps, easy to follow.
