Hi all,
Some help from the collective please.
2016, manual t6, t30, 140bhp.
Drove 70m home from London yesterday, nothing to note on the journey but coming off the motorway i started to hear a clicking/clacking noise, regular pattern, rotational? that seems to be mainly on right hand turning under load. It sounds a bit like a torque wrench click/clack, if that make sense but obviously loader. A bit more investigation today. Nothing loose, nothing hanging down under the van, no fluids on ground, nothing in tyres/wheel arches. Drove it round a car park to test. definitely only under load, predominantly right hand turn but a bit also under left hand turning as well. Noise 'appears' to be from nearside front. I'm suspecting drive drive shaft issue and when I got home I looked under the van at the nearside drive shaft, felt around the wheel end and there is grease and the gaiter is split.
I think I've probably answered my own question on the cause of the sound but would welcome opinions if I'm right to assume the drive shaft and if I should consider anything else.
Also, It has only just started. Only present under low gear tight turning. Is it OK to drive for a couple of weeks until I get a garage lined up? Likely only do some low milage local journeys and 2 trips to London and back. thoughts?
Thanks Guys
Thanks Guys
