Hi Guys & Girls, 1st post introing my lockdown conversion. Purchased May '20 as an ex builders run around with the plan to turn it into a van to haul around my work gear (Im a Freelance Sound Engineer) and also act as a weekend warrior overnighter with Stitches + Steel conversion. The SS conversion has 3 draws that will carry mic stands, microphone flight cases and cable trunks, then the load space will hold 19" Flightcase trunks & instrument cases.
1st Pic the day we collected her in Somerset. 150ps SWB Tailgate.
Soon after Wheel's are swapped for 20" Steels with 255/35's on 9J and a de-chrome with accompanying Black Badges & Sidelights.
The Side window was installed by the chaps at Unique Vans.
Next Step was a full Dodomat & Thermo lining & accompanying carpet fir out and custom 1 peice ceiling & LED Lights. Followed by the wonderful guys at Stitches + Steel installing their full rear conversion.
Hidden in the recesses between the draws are the Lesiure Battery & 2000w Inverter powering the Nespresso machine!
This week's Job is to install this pair of Nappa Leather Recaro Trendlines into the cabin, with swivel base on the passenger side.
Jobs to do next:
Late September I've got a booking with Transporter HQ to install a set of SoLow's with shaved Top Mounts & rear deletes to get this lower than a snake's belly. If in stock then LED DRL's will also be installed, and then the following day a set of rear 6.1 LED lights are being installed with Professionalretrofits.
I think at that point it's a rest then an Audio overhaul but that will have to wait a little longer!
Would love to know your thoughts so far, but its been a busy few months getting it this far.
Jobs to do next:
