Carista - Activate Fuel Lifter Pump?
Dellmassive
VCDS User
Moderator
T6 Master
So we have VCDS etc, but my question to the Carista guys is . . . . . . .
well first let me explain,
on our old T5 if it run out of fuel we needed to use VCDS to prime the fuel system by activating the Lifter pump and secondary pump before we could start the van....No problem with the laptop and Rosstech cable which we have.
we already have ELM327 and other bluetooth dongles, and Tourqe Pro APP on android . . . . .
So weve purchased Carista today, just to have a play and see what it can do......
so im the mean time, the question is . . . . can you bring up the modules and activate live functions?
ie
turn rad fan on/off,
enable fuel lifter pump for 30 seconds
enable lights in turn to test
activate EGR % comand
Basically the stuff we can do with VCDS or Autel or Versus D10 Pro?
Carista be used as a "keep-in-the-van phone APP + dongle" as a get out of jail card for fuel priming a dry van? - in case the laptop is dead or the Rosstech lead has been stomped on by an elephant etc
No Carista can only turn on/off predefined functions, it has no coding/adaption or measuring abilities
