Can bus emulator?
Power ut
RSQ3 engined
Not sure if anyone can help advise. I’ve done a audi conversion on my old 06 t5 but as I fitted the t6 dash I fitted the climate 3 knob control panel which due to canbus been not compatible , any idea what I need or can use to power the heater controll pannel up?
Don't know whether you could fit a separate T6 BCM just for the heater. I guess you'd need to retrofit the whole T6 heating system to work and maybe an additional ODB port for it.
The t6 heater pannel powers up in a caddy/ t5.1/t6 / Tiguan/ I can add the power and earths and evern see contect in vcds , but only shows part of the climate unit , as I belive the canbus wakes module up so it will power dails/ buttons ,
But not sure what I can use , without adding a full set up , ?
