Hi all - need some advice please. We have an Autohaus Ashton T6.1 camper conversion, 2022. Having not used the Webasto diesel heater for months, I did a quick test of it a couple of weeks ago. It worked fine. I turned on the main control panel before testing the heater as I assumed the leisure battery had to be on to power up the diesel heater. All good. Turned the heater off. Walked away happy. Realised today, 2 weeks later, that I forgot to turn the leisure battery control panel off I checked late tonight on realising my apparent error. The control panel is beeping. Nothing showing on the control panel display. I fear the leisure battery is completely drained as presumably the fridge has been on all that time. It’s relatively new as a battery and has a 100w solar panel feeding it too. So perhaps it’s not been drained for too long. I have a couple of questions:
1) Is it survivable? Any tips on how I can revive it? Currently planning to take it on a drive tomorrow to see if that kicks it into action.
2) If I need to replace it is that easy, as in can I do it or will I need a specialist to do it? And can I get a bigger battery or does it need to be the same capacity?
Thanks for any guidance. This is the battery it has:
