Any dq500 techical question I've hit a abs / traction issuises biggish problem .
Power ut
RSQ3 engined
Currently have a rs3 engine and matching gearbox in a old 06 t5 . Which starts runs drives . But I carnt adapt g85 and some other abs settings as I carnt fit the audi rs3 steering rack ,.
So if I fitted a t5.1 abs unit which will then match cluster and g85 module . But I'm not sure .if the audi dq500 will see the speed signal for the abs . .dose anyone know . As normally u use the transporter dsg modifyed to the engine??
As its only way I can think I can do basic settings for the esp/ abs/ traction lights to adapt and go off ? Then she's mot ready
