Hi all,
2021 Camper King conversion (on a 67 plate T6). We don't use the sink often but yesterday we took some water with us and I emptied it out today. Unfortunately you can't drain the tank directly but have to run the tap into the sink until it's empty.
I thought the water pressure was a little bit weaker than usual but did not think much of it. Water drained out the drain hose.
But when the tank was empty I also noticed water under the van underneath the sink area. And on closer inspection the floor got wet too.
I suspect it might the connection to the tap itself, which may also explain the lower water pressure.
I'm a little unclear on how to gain access to under the sink - the fridge is directly underneath. I'm wondering whether that needs to come out...
Has anybody got any experience with gaining access to under the sink in a camper king conversion? Any guidance greatly appreciated.
Martin
Martin
