Bulb out warning light
Chris1983
Hi all,
Wife pointed out ‘bulb out’ light illuminated today.
No bulbs are out?!
Only change is recent work by the excellent Davtec.
Any idea where to start looking?
I do not have VCDS access?!
Many thanks in advance,
Chris
Mines because of LED indicators but you’ve said you don’t have any LEDs so there goes that idea…..
It could just be a poor connection to one bulb.
It’s a pain, but try removing each one in turn and cleaning it up, then re-inserting.
Pete
I sometimes get a bulb out warning if the starter battery is low but it goes out if the van is restarted after a short run
If you follow my logic (which might be wrong!);
If the bulb out light illuminates on start up it's probably linked to a DRL.
If it doesn't, then try in turn illuminating brake lights, dipped headlights, main beam, right indicator, left indicator and so on.
You might notice that the bulb out light illuminates whenever you do any one of those things, which would give you a starter for ten.
