Sorry if this has been posted before but where does the yellow/green linbus wire go to on the alternator is it this connector in the image attached?
If so how do you get it off its solid and I don’t want to force it.
I’m having the common issue of alternator not charging and stop start error. I’ve checked the wire under the sump and it seemed ok so want to do a continuity test from the bat negative shunt to the alternator yellow/green wire.
