Interesting to see that this fault appeared a few minutes after running the engine for a while and then doing a scan. It has come up before and I wonder where the issue is. Could it be that there's a blockage in the actual pipe coming from the pump itself and the injector - rather than the actual injector or pump being at fault? I really don't think the pump is at fault and the injector seems to be working OK. Maybe I can blast some compressed air through the supply pipe to clear it? Or run a mountain bike brake cable through it to clean it out?
Does anyone know how long the actual dosing line is?
Sunday,03,August,2025,13:12:08:16365
VCDS Version: Release 23.11.0 Running on Windows 10 x64
www.Ross-Tech.com
Address 01: Engine Labels: 04L-907-309-V2.clb
Control Module Part Number: 04L 906 056 KA HW: 04L 907 445
Component and/or Version: R4 2.0l TDI H02 6163
Software Coding: 00114014430501090000
Work Shop Code: WSC 02737 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056KA 004012 (VN75)
ROD: EV_ECM20TDI03004L906056KA.rod
VCID: 76B5E6C56844C36A05F-8022
1 Fault Found:
31149 - Reductant Flow
P218F 00 [01100000] - No Flow Detected
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 272571 km
Date: 2096.01.10
Time: 11:58:42
Engine RPM: 823.50 /min
Normed load value: 35.7 %
Vehicle speed: 0 km/h
Coolant temperature: 30 °C
Intake air temperature: 29 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 13.367 V
Unlearning counter according OBD: 40
Outside temperature sensor 1: B1: raw value: 23.5 °C
Reducing agent pump module relative press.: calculated: 777 mbar
Reducing agent fill level sensor: act. value: 88 mm
Sensor for reducing agent tank temperature: temperature: 21.5 °C
Reducing agent system pressurization release conditions-Engine running: Condition not met
Reducing agent system pressurization release conditions-Press. enabled: Condition not met
Reducing agent system pressurization release conditions-Heat. strategy: enable: Condition not met
Reducing agent system pressurization release conditions-Depressurized min. time below limit: Condition not met
Reducing agent system pressurization release conditions-Catalyst temp.reached: Condition not met
Reducing agent system pressurization release conditions-Release due to jammed valve needle: Condition not met
Reducing agent system pressurization release conditions-Rinse function finished: Condition not met
Reducing agent system pressurization release conditions-Initial filling completed: Condition not met
Reducing agent system pressurization release conditions-Release via inducement: Condition not met
Reducing agent system pressurization release conditions: 127
Readiness: N/A
