Ad blue Alert - US and UK gallons incorrect compared to litres ..why ?
lucky13
So i’m getting an Ad blue alert for 2.5 UK gallons, if I go into the settings and change the units to US gallons it still says I need 2.5 US gallons which should be completly different but it doesn’t seem to think so, but if I go into units and change it to UK litres then it suddenly becomes 8.75 litres …what on earth is going on and which figure do I use as nothing makes sense!!!
For info:
2.5 UK gallons is 11litres
2.5 US gallons is 9.6litres
  • Wow
I've always just looked at the higher figure in gallons multiplied by 8 and then divided by 2 which puts you roughly in the middle of the required range. Worked for the last 70k miles.
My van gives a minimum and maximum quantity to put in, and I put in a little under the maximum recommended. My display is in litres.
I would do what it says in litres.
