5 speed to 6 speed?
Simkool
Tried tocsesrxh but could find anything to cover it
I got a 2016 2.0tdi 5 speed qwm gearbox which is noisy
What other 6 speed gearbox’s bold stright on in a conversion
And what other parts do I need
Starter
Driveshafts
Linkage cables
Bolts
Dmf/clutch
One minor point is the display on the dash will not recognise 6 gears. If you are not bothered then it does not matter but you may be able to have the ECU reprogram to tell you the correct gear.
Would that affect cruise control and the like?
I’m not 100%, but I’m sure I’ve seen a section in VCDS that lets you configure the gearbox setup.
I have changed from a manual to DSG but that was on an older caddy. Not sure what the transporter allows or what the options are ( 5 to 6 speed)
Could get a ECU kit from then doner van and swap the millage and immo data over
