255/35/20 on 9J wheels
255/35/20 on 9.5 on the rear 235/35/20 on 8.5 on front
Waiting to get air put on soon
It’s only on standard sportline springs etc as waiting to have Accuair ABP CVT fitted when it’s released, soon I hope
Looks good, I ordered 20" 9J wheels with 255/35 tires. Maybe should go with 275/35..
You might find 275/35/20 on 9" rims might rub on the fronts. There seems to be a sweet spot of 265/40/20 if you read some of @BognorMotors posts.
Personally I think 35 profile is a little too skinny unless as @LpeppsT6 said, you're going on air and you want that slammed look.
Yep 235/35 do look very skinny it’s surprising the difference on the 255/35 on the rears, when air is fitted I think I’ll change the front depends what fits and how low it goes
255/40 on 9J wheel, I quess is the best looking combination. I will try first with 255/35, incase it doesn't work I will change. I will upload some pictures when I'm getting my BBS SX on, CANT WAIT! :D
You'll be fine with the 275/35 - Perfect size - You may just have to heat the inner arch liner. the 265/40 is the tyre we have found works best for a T32.
HTH
