Help!!!
We’re trying to get our heads around the proposed battery system for our conversion.
Our converter has recommended the LPS [URL]https://www.claytonpoweruk.com/lps/[/url] stating that we could run an induction hob off it if we wanted. This idea appeals. However trying to get our heads around battery life is more than I’m capable of. I’m fine working out the 12v side, but how long can the system run for on 240v? My basic (very basic) understanding is the dometic fridge for example will be significantly more efficient on 240v, but I don’t understand how long it would then last for? Surely you lose something???
Example:
200w appliance.
On 12v draws 16.6a. So would last 6 hours on 100amh battery
On 240v draws 0.87a so would last 114hours on 100amh battery.
Is that right? I know I haven’t taken efficiency of inverter in to try and make my life simple.
In my mind we’re getting something for nothing here. I feel you should get significantly less because you’ve upscaled the voltage.
the end calculation would be if we can run a double induction hob without killing the battery
Example:
200w appliance.
