235 65 r16 on Clayton?
Drebin
Hi all,
After a bit of advice, I'm looking at agilis-crossclimate 235 65 16s putting them on the factory Claytons. Has anyone done this? Any problems fitting a 235 on a 6.5j rim?
Reason for the 235s is that I'm hoping for a comfier tyre. I currently have 205 65s which just seem to small and pumped up to the max.
Also if you have gone 235 65 16s what tyre pressure have you found works
Many thanks
Yeah that was the other size I was looking at due to it being pretty much spot on with the speedometer.
Maybe a bit less of an issue with the 6.5 rim too
Brilliant thank you.
Reactions: mmi
Ok. Maybe reduce your pressures a bit then. Remember the higher suggested pressure is fully loaded loaded as a commercial vehicle.
Ok. I would look at suspension before you start changing tyres. That will give you the biggest benefit although will cost more.
Hi all,
Many thanks
215/65 on my Claytons. Agilis Cross-climates.
Not sure 235 would go well, and 215 is on the VW sticker.
Very happy with them.
