204ps DPF Pressure VCDS
t6boy
Hi all.
Looking through VCDS to try and diagnose my problem.
I can't find in the Measuring Blocks. The DPF Pressure Difference reading.
I have dPF pressure reading bank 1 etc and shown in MBAR not HPA.
It's labelled particulate differential or something similar and there's 2 readings pre and post
It's in the "Advanced Measurement Values".
Perhaps "IDE07744 Particle filter: air pressure sensor 1 bank 1: raw value"
It's fairly simple conversion : mbar = hPa
What's your problem?
Problem.
VW Vortex - Volkswagen Forum
O
2.0 BiTdi LIMP Mode. DPF​
TagsNone
Jump to LatestUnfollow
1 - 2 of 2 Posts
O
·Registered
Joined Jan 8, 2018
Discussion starter·#1·2d ago (Edited)
Hi.
Long story. Split Intercooler hose, then van tried to do a burn and couldn't, then went into LIMP mode with 2 faults.
Soot level too high and EGT sensor.
Cleaned the sensor and that fault has gone.
VCDS SCAN.
VIN: WV1ZZZ7HZJH069108 Mileage: 107990km-67101miles
02-Auto Trans -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (2D2D2-CXEB) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KQ HW: 04L 907 445 A
Component: R4 2.0l BTD H03 3775
Revision: 23101001
Coding: 00254014432401080000
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_ECM20BTD03004L906056KQ 004004
ROD: EV_ECM20BTD03004L906056KN_004.rod
VCID: 0652499078A19B1AB56-8052
VINID: 9E606AAAA1D8A9A60018904020858E8D84
1 Fault Found:
23902 - Particle Filter
P2463 00 [10101111] - Excessive Soot Accumulation
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 107993 km
Date: 2082.01.11
Time: 02:23:47
Engine speed: 822.00 /min
Normed load value: 31.8 %
Vehicle speed: 0 km/h
Coolant temperature: 46 °C
Intake air temperature: 26 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.421 V
Counter for regeneration time of particulate filter: 2138 s
Particle filter: kilometers since last regeneration: 3737.1
Particle filter: soot mass measured: -3.19 g
Particle filter: soot mass calculated: 59.99 g
Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: 0.1 mbar
Particle filter: field regeneration lock status: 8
Trying to work out if the Pressure Sensor is dodgy.
Please share engine blockmap files
1) Ignition ON - engine OFF
2) Engine running at idle
VCDS > Applications > Controller Channel Map >
Tick/fill boxes as above and click Go.
VCDS flashes screens for a moment (when finished click "Done, Go Back") and in folder C:\Ross-Tech\VCDS\Logs\.... there will be the files blockmap-01-...
Note: only VCDS HEX-V2 and VCDS HEX-NET cables have the capability to create blockmap files.
1 Fault Found:
Based on the data this is quite obvious:
IDE00432 Particle filter: time since last regeneration 7360 min
IDE00436 Particle filter: kilometers since last regeneration 4172.6
Typically on this engine DPF regeneration occurs at 200-250 km intervals - thus been driven without regen 15-20 times more than normally.
IDE00434 Particle filter: soot mass calculated 60 g
The soot counter maxes out at 60 grams - as normal value on this engine is 6 grams right after the regen, and 24 grams triggers the regen - thus accumulates 18 grams during before the regen happens.
So the actual value (calculated) should have been somewhere at 300-400 grams.
IDE00435 Particle filter: soot mass measured -1.55 g
I believe that the measured value is actually based on measured pressure across the DPF itself and normally would expect see here values less than in the soot calculated. Normally would expect to see values from -6 to 10 grams - correspondingly with soot calculated from 6 to 24 grams.
However, seeing now (long time without DPF regenerations) such a low value of soot mass measured makes me wonder if the DPF has cracked and thus not blocking/filtering the soot anymore.
IDE07744 Particle filter: air pressure sensor 1 bank 1: raw value 7.6 mbar
Also the pressure across the DPF (above) is suspiciously low for not having had DPF regenerations for such ong time. The 7.6 mbar is something to expect immediately after a DPF regeneration at your mileage.
Have you checked the tailpipe - is it sooty?
That's on paper towel, rubbing up inside the tailpipe a good 4".
I counted my fuel receipts and 4,000kms is correct. It did a burn (DPF) light came on just after the boost pipe split.
Not bad, but not perfect either.
The way forward would be to recondition the DPF - either clean or replace with a new. Doing a forced DPF regen might be a risky thing to do as the DPF obviously has collected quite a bit of soot.
I'm just trying to get all the info I can. It's a work vehicle and I only have a small window to do it.
I've got some DPF cleaner, which I'll spray. Then I seen a YouTube video about changing values or telling the van its got a new DPF and then trying a Sevice Regen.
Just didn't want to do the NEW DPF when it was clogged due to the fire risk.
