Dnaa Leak off pipes
Volkswerks
Hi all im having fuel pressure problems ticks over fine then drive it go above 2k revs it then misses and cuts out caused by the fuel pressure regulator.
I've done a lot of reading and wanted to rule this one out there is a plastic non return valve/pressure valve on the return pipes I've cleaned it with Bcc and then blew through it which was fine but should i be able to blow the other way as i can but not as much air comes through is it non return Thanks
