Morning. I've just fitted some Phillips LED head lights etc and now want to change my fogs to LED as well so it matches. How easy is it to change the bulbs? I've looked for videos but can't find any
Simple job, its easier if you turn the steering wheel onto full lock then there is an access hatch in the front arch liner that gives you direct access to the rear of the foglights, the lamps just twist and pull out
Nice one thanks! Having spent an hour or so upside down in the engine bay with hands in small gaps for the headlights, I was concerned that this job may be a headache!
took me 20 mins to do both a few saturdays ago. Buy some small cable ties so you can tie up any loose hanging wiring to the OEM wiring loom, if, like me, you are a bit handfisted, then it might be an idea to ask the missus or a small child to do this bit as its super fiddly and getting two hands in is a task
